Configures the remote ID sub-option to the default value.
vrid | Specifies the VR on which to configure the remote ID sub-option to the default value. |
The switch MAC address.
None.
The following example configures the remote ID sub-option to use the default value on the current VR:
configure bootprelay dhcp-agent information remote-id
This command was first available in ExtremeXOS 12.4.
